Care and Appearance Washing, waxing, paint care products, etc.
License plate bolts
Old Oct 13, 2024 | 07:29 PM
License plate bolts
Do the plastic inserts and large, coarse thread screws commonly seen on parts sites really cover from 61-77? They went back that far?
Old Oct 13, 2024 | 07:42 PM
Funkwagon455's Avatar
I believe the inserts were fairly typical, but the screw heads have been liberated. I’ve personally struggled with this conundrum myself.
Old Oct 14, 2024 | 06:23 AM
JohnnyBs68S's Avatar
My '68 uses 4 similar looking screws, but use the stamped spring metal speed nuts (I think that's what they are called). I'm confident they are original.
Old Oct 14, 2024 | 08:32 AM
Do you think I'll get points deducted at a show for the black plastic HELP! brand ones I use?
Old Oct 14, 2024 | 09:50 AM
Maybe.
That speed nuts info is good. Typically I run bolts through the plastic with nylocks on the back and antitampers on the heads. But, this car will get stock, and, 4 of them.
Old Oct 14, 2024 | 10:16 AM
70Post's Avatar
I've seen those as well but also see the nylon insert version.....
...this may have been a deal where it was WHAT THE CAR DEALER used at the time instead of what the factory did (ie - what style of fastener and nuts).
If potential originality matters you may be better off with a large pan head (or round head) SLOT screw head instead of a philips head. I pulled MANY of these things off salvage yard cars over the years and the large diameter slotted head screws were the most common. Can't guarantee anything and again, I think this stuff was dealt w/by the car dealer.
I also think the tips of the original screws were likely blunt instead of a sharp point...for obvious reasons on the rear plate setup.
Old Oct 14, 2024 | 10:35 AM
70Post's Avatar
Pic....
Old Oct 14, 2024 | 10:37 AM
70Post's Avatar
Originally Posted by Funkwagon455
...........................I’ve personally struggled with this conundrum myself.
No worries - there are "License Plate Screw Head Encounter Group" meetings scheduled in many parts of the country for people like you. They are really helpful.
Old Oct 14, 2024 | 11:15 AM
Stop badgering me Patton, I already told you that I’ll be there on Thursday!! Criminy!!
Old Oct 14, 2024 | 02:10 PM
I have found some supposedly nos kits on ebay. Nylon insert, coarse screw with blunt tip, combo phillips and flat slot head. Appropriate finish. I will attach the plate with 4 of them as this plate does not have to come off.
Thanks for help.
Old Oct 23, 2024 | 07:57 PM
Ended up plugging those into the license plate door on top. So that's two screws. They would not plug into the bottom so I used some speed nuts for additional bolts. Need to paint back of tag sometime.
Old Oct 23, 2024 | 07:58 PM
photo off phone so double post.
YukonOlds
Aug 31, 2023 02:41 PM
72455
Jan 5, 2023 07:13 AM
cutlassefi
May 3, 2014 08:41 AM
1970 Post
Jul 17, 2012 12:10 PM
Moses
Jun 10, 2011 09:37 AM
