Care and Appearance Washing, waxing, paint care products, etc.
Original Trico Wipers - Refills / How To??
Old Jul 15, 2024 | 12:06 PM
mapearso's Avatar
1978 Delta 88
Dumb a## question but I don’t want to break anything….
How to remove this wiper blade from the arm so I can install new rubber?
I can’t imagine that I have to remove the whole arm .. or try and install the new rubber with everything on the car??
Old Jul 15, 2024 | 01:24 PM
rocketraider's Avatar
Oldsdruid
Use a flat-blade screwdriver, preferably with a wide blade, and pry between the blade and the gray plastic piece on the arm. The blade will pop off that spindle thing. Use a drop of thin oil or penetrant on it if needed.
Old Jul 15, 2024 | 01:45 PM
I would just install new inserts into the existing blade while it is attached to the arm. That's what I do on my vehicles.
Old Jul 15, 2024 | 02:33 PM
Not quite. The screwdriver goes in the slot and presses down on the coil spring. This releases tension on the pin, allowing you to pull the blade off the pin. Levering against that plastic piece risks breaking it.
From the Chassis Service Manual:
Old Jul 15, 2024 | 03:39 PM
mapearso's Avatar
Thanks so much Joe. Very helpful. Like I said, didn't want to break anything for something as simple as this ...
Old Jul 15, 2024 | 04:32 PM
redoldsman's Avatar
Proud Viet Nam Veteran
I have had trouble finding refills. Where are you guys getting them?
Old Jul 15, 2024 | 05:25 PM
I bought a bunch from Rock Auto several years ago. Last time I bought 22" refills and I cut them down to size - I have a Jeep that uses 13" and those refills have been unavailable for a LONG time now.
Unfortunately, many of the refills are being discontinued, which is why I buy the longer ones and cut them down. Even many of the selections in longer sizes are being obsoleted.
Old Jul 16, 2024 | 05:35 AM
Trico Classic Series, but some of these have been hard to find of late. My go-to is the fricken', er, I man Ficken Wiper Guy , who always has the 15" and 16" refills.
https://rebuildingtricowipers.com/
Old Jul 16, 2024 | 07:48 PM
mapearso's Avatar
I just bought some 18” “classic” wiper blades from NAPA. They are supposed to arrive tomorrow. I’ll post photos of them
Old Jul 17, 2024 | 10:29 AM
mapearso's Avatar
Well picked these up … Let’s see how they fit
zl1 camaro
Mar 11, 2024 06:17 AM
Destructor
Dec 10, 2018 03:19 PM
stlbluesbrother
Aug 9, 2012 08:38 AM
stlbluesbrother
Aug 6, 2012 04:34 PM
Napoleon Solo
Jan 6, 2012 02:42 AM
