Care and Appearance Washing, waxing, paint care products, etc.
Best product for rubber weather seal preservation
Old Apr 18, 2022 | 06:51 AM
Hi guys,
I'm looking for recommendations for the best product/s to preserve and keep the rubber weather seals around my doors and my trunk nice and supple. They're newer right now, just want to keep them that way as long as I can. Thanks in advance!
Old Apr 18, 2022 | 07:01 AM
My442's Avatar
Thumbs up
303 makes the best rubber product.
Old Apr 18, 2022 | 07:20 AM
My442 - Thanks for the quick reply, much appreciated!
Old Apr 18, 2022 | 07:51 AM
Silicone spray.
Old Apr 18, 2022 | 07:56 AM
72455's Avatar
1972 U code Supreme
^^^x2
Old Apr 18, 2022 | 08:15 AM
69HO43's Avatar
303 is the likely the best "readily available" product at the box stores for not too much money. I think it works great as a dash preservative and other plastic pieces.
GM used to call out for dielectric grease on weatherstrips. But that has silicone in it, and if you have vinyl film coating on your weatherstrips, silicone may be corrosive to that coating.
But IMO, for weatherstripping, Krytox is the cat's *** when it comes to weatherstrip preservation. PURE PFPE/PFTE stuff. Chemically inert, non-flammable, highly resistant to oxygen attack. No sticking. Like adding a teflon coating to your window seals. Glass slides across it easier. Temp range -36C through 204C, so it's pretty temperature stable in any weather. A tiny bit goes a good way too. Its initial cost is rather pricey, but worth it when using genuine GM weatherstrips that aren't readily replaceable. For an inside car that doesn't spend its life in the elements, re-doing them about 6 months to a year may be too often, not sure. Applied right it's not oily or greasy and keeps the weatherstrip in very nice condition.
Got an 8 oz. tube of GPL205 grease and 1 oz. small bottle of GPL105 oil and I'm probably set for life.
Interestingly, GM used to sell a 1 oz. bottle of re-labeled Krytox as Weatherstrip Fluid, GM p/n 3634770.
Old Apr 18, 2022 | 08:32 AM
oldcutlass; 72445; and 69HO43 - Thanks to all of you for your recommendations, all are greatly appreciated. As a side note, car is garaged and out of the elements, so I'm really just looking for a product thats easily applied and keeps the rubber supple.
Old Apr 18, 2022 | 08:44 AM
I've used silicone spray for over 40 years with great success, I spray it on a rag and wipe the weatherstrip down with it. It's what dealers used for decades. I've never tried the other products mentioned by others.
Old Apr 18, 2022 | 09:05 AM
Sugar Bear's Avatar
GummiPflege by Sonax
Old Apr 18, 2022 | 10:05 AM
oldcutlass and Sugar Bear - Thanks for the additional responses, much appreciated!
Old Apr 18, 2022 | 12:16 PM
Silicone spray.
^^x2^^ Hands down the best, IMO.
Old Apr 18, 2022 | 12:21 PM
Thanks Norm, much appreciated!
Old Apr 18, 2022 | 12:31 PM
Dollars-to-Donuts says 303 is composed of silicone - its base compound (Polydimethylsiloxane [PDMS - a group of polymeric silicon compounds commonly referred to as silicone]).
Old Apr 18, 2022 | 12:38 PM
Norm - Thanks for the additional sleuth work, good to know!
Old Apr 18, 2022 | 01:01 PM
bccan's Avatar
Krytox is the best I’ve personally used and priced accordingly, I actually got it through the VW dealer, Wurth Rubber Care always worked well, good ole silicone is cheap, available anywhere and certainly works.
Old Apr 18, 2022 | 01:14 PM
Thanks for chiming in Brian, much appreciated!
Old Apr 18, 2022 | 01:19 PM
69 Hurst's Avatar
Olds Fanatic
Been using 303 for over 10 years, wouldn't use anything else.
Old Apr 18, 2022 | 01:39 PM
69 Hurst - Thanks for the input! After reading up on the 303, sounds like I could also use it on my black vinyl top too, do you have any experience using it for that application?
Old Apr 19, 2022 | 09:59 AM
69 Hurst's Avatar
Olds Fanatic
I do not, but I think it could work well.
Old Apr 19, 2022 | 10:13 AM
Thanks for the response. I'm going to search on here for a thread about vinyl roof maintenance, there's got to be one, just haven't had time yet.
oldsmike1972
Apr 18, 2022 04:41 AM
DFitz
Oct 12, 2021 02:34 PM
yellowrocket
Jul 15, 2018 08:23 PM
oldstata
Aug 29, 2014 11:11 PM
cfair
Jul 19, 2009 09:22 AM
