98 Olds Bravada lots of hot air
Old April 9th, 2008 | 04:56 PM
jefnmic's Avatar
My 98 Olds Bravada only likes to blow hot air. I looked at the post by Cliffg8 sounds just like his problem that he had and looked at the air mix door moving it back and forth but for some reason I don't think the actuator is working. The door just wants to move back to the same postion each and every time. So, is the actuator bad or what controls the actuator bad....? It does blow cold air when the door is moved to a certain position. Any input would be greatly appreciated.
Old April 9th, 2008 | 05:49 PM
Redog's Avatar
Were they vacuum controled in 98?
Do you feel it move when turning the *****? Sometimes in the cold months I gotta turn the Alero's ***** slow, or the same thing happens
Old April 9th, 2008 | 06:01 PM
jefnmic's Avatar
I had someone moving the **** switching back and forth from cold and hot and I watched the air mix door and it would not move on it's own. I can move the door by hand but when I let go it moves back to the same position everytime no matter where the **** it positioned.
Old April 10th, 2008 | 12:44 PM
Oldsguy's Avatar
Past Administrator
If it is vacuum controlled there may be a leak in the control head manifold or in the tube to the door actuator.
84oldsDelta88
20
January 12th, 2016 02:36 PM
copper128
October 18th, 2013 02:01 PM
WTony
July 3rd, 2010 12:12 PM
dan1s
April 17th, 2010 09:14 AM
beanship
Bravada
June 9th, 2007 07:44 AM
