98 Olds Bravada lots of hot air
Old Apr 9, 2008 | 03:56 PM
jefnmic's Avatar
My 98 Olds Bravada only likes to blow hot air. I looked at the post by Cliffg8 sounds just like his problem that he had and looked at the air mix door moving it back and forth but for some reason I don't think the actuator is working. The door just wants to move back to the same postion each and every time. So, is the actuator bad or what controls the actuator bad....? It does blow cold air when the door is moved to a certain position. Any input would be greatly appreciated.
Old Apr 9, 2008 | 04:49 PM
Redog's Avatar
Were they vacuum controled in 98?
Do you feel it move when turning the *****? Sometimes in the cold months I gotta turn the Alero's ***** slow, or the same thing happens
Old Apr 9, 2008 | 05:01 PM
jefnmic's Avatar
I had someone moving the **** switching back and forth from cold and hot and I watched the air mix door and it would not move on it's own. I can move the door by hand but when I let go it moves back to the same position everytime no matter where the **** it positioned.
Old Apr 10, 2008 | 11:44 AM
Oldsguy's Avatar
Past Administrator
If it is vacuum controlled there may be a leak in the control head manifold or in the tube to the door actuator.
84oldsDelta88
20
Jan 12, 2016 01:36 PM
copper128
Oct 18, 2013 01:01 PM
WTony
Jul 3, 2010 11:12 AM
dan1s
Apr 17, 2010 08:14 AM
beanship
Bravada
Jun 9, 2007 06:44 AM
