2000 Bravada---Jerking feeling
Old Jun 15, 2007 | 04:27 PM
LisaR's Avatar
I have a 2000 Bravada, 75,000 miles with a strange condition that the dealership mechanic can't figure out. I start out on the highway and everything is running smoothly. If I stop and start up again the car feels like it is going over the seam lines in the road. Then get up to about 60mph it stops. The mechanic hooked it up to the computer and everything checks out good. He called GM and they don't know what it is. He seems to think that it is something in the transfer case slipping but can't find it. He wants another Bravada to look at and compare to mine. It doesn't do it all the time, just mostly on the highway. He also thinks it may have something to do with the all wheel drive. Anyone eles have this problem???
Lisa
Old Dec 19, 2007 | 07:46 PM
rocketraider's Avatar
Oldsdruid
My 97 has started doing the same thing at 165k miles. Starting off uphill or under any load or moderate acceleration, it will pop and clunk until it gets into 3rd gear, and sometimes when making a turn. Since Bravada AWD operates much like a positraction unit, I expect it has something to do with worn clutch packs.
However- with 165k, I'm not in a hurry to fix it as the truck itself isn't worth the expense of replacing the transfer case. I'll drive it till it quits, then I will junk it. It's been a fairly troublesome and high-maintenance vehicle anyway, especially compared to the K-car and the Custom Cruiser wagon.
Old May 22, 2008 | 01:33 PM
atownhockey19's Avatar
does it sound like its grinding...very loud...mine 98 did that and had the transfer case replaced along with the differential for about 1300 if i remember...fixed the problem
Old May 22, 2008 | 04:11 PM
Oldsdruid
Makes less than no sense to spend $1300 on a vehicle that wholesales for slightly over $2000.
I parked mine 2 months ago. It has to have a pitman arm to pass VA safety inspection and I'm just not inclined to spend any money on it. I have too many other vehicles more deserving.
$1400 will buy it if anyone's interested.
Old May 22, 2008 | 06:02 PM
trade it in for a kia
they will give you 3000
scoutdad57
Bravada
15
Jul 12, 2010 06:50 PM
beanship
Bravada
Jun 9, 2007 06:44 AM
wbrwolfman
Bravada
Jun 1, 2007 08:59 AM
smason
Dec 6, 2006 04:47 PM
