Hot steering fluid
Old Mar 22, 2013 | 10:12 AM
1966Oldsmobile's Avatar
Hot steering fluid
Hello!
I filled in the steering fluid (Castrol Transmax Dex III) 1 inch under the cap.
Then I drove 30 miles.
After it the steering fluid was hot (about 140 F°) and there was steering fluid on the cap (and it spilled out during driving).
Why? and what should I do?
Thank you very much
Old Mar 22, 2013 | 10:43 AM
ihengineer76's Avatar
Did you fill to the line on the dipstick on the cap? If you put in too much, the fluid got hot, expanded, and spilled over.
Old Mar 22, 2013 | 10:52 AM
There is no dipstick on my cap! From the edge of the steering fluid tank 1 inch (cold fluid) down.
Is that too much? What about the temperature?
Old Mar 22, 2013 | 01:42 PM
140F is not hot, and you possibly just over filled it. Just keep an eye on it for a while and see if it's ok.
Old Mar 22, 2013 | 02:38 PM
dancutlass's Avatar
Daniel, there is a line stamped into the reservoir!
Old Mar 22, 2013 | 02:47 PM
Hi Daniel!
Did not get the TÜV today!
Thanks to all your help, will keep an eye on the fluid level.
Old Mar 22, 2013 | 02:54 PM
tecar442's Avatar
I did the same thing with my '67. What a mess. I find that if I keep the fluid level a little lower than the fill line, when hot, the fluid just touches the line and no mess.
Mak
May 31, 2013 01:56 PM
Redog
Mar 18, 2012 09:21 AM
67Olds442X2
Jun 14, 2011 06:20 PM
cfair
Brakes/Hydraulic Systems
Jun 8, 2009 12:37 AM
Oldsproject
Jun 21, 2008 07:03 AM
