Brake Distribution Block / Prop Valve GROUNDING
Old Aug 7, 2011 | 07:03 AM
dgy's Avatar
dgy
Question Brake Distribution Block / Prop Valve GROUNDING
Question:
Does the brake distribution block (Proportioning valve) mounted on the left front frame rail, need to be grounded to chasis for the brake failure switch to work?
(re: 71 442)
THANKS!
-Dave
Old Aug 7, 2011 | 09:30 AM
jensenracing77's Avatar
it will still be grounded through the brake lines.
Old Aug 7, 2011 | 10:09 AM
Originally Posted by dgy
Question:
(re: 71 442)
THANKS!
-Dave
If it's bolted down, it IS grounded. And to answer your question, yes.
Old Apr 6, 2012 | 10:13 AM
oldgold's Avatar
proportioning valve
Joe: I'm swapping out the front power drums to power Disc.Do i remove the stock Distribution valve and install the proportioning in it's place?or do i leave the distribution valve alone and install the Proportioning valve elswhere.Thanks,Tom.
Old Apr 6, 2012 | 10:23 AM
boese1978's Avatar
Hi Tom, I just did this on my '68 ( not sure what you are working on) on mine, it is JUST a distribution block and I had to add a proportioning valve between the dist block and the rear brakes.
Old Apr 6, 2012 | 11:03 AM
You can either add a standalone prop valve in line with your current distribution block (as the factory did for 1967-1970), or you can replace the distribution block with a combination valve (distribution block and prop valve combined in one housing). Your choice, either works.
sicky olds
Mar 3, 2014 06:52 AM
Team13Racing
Brakes/Hydraulic Systems
May 31, 2013 09:58 AM
garys 68
Sep 18, 2012 10:20 AM
Team13Racing
Aug 11, 2012 09:37 PM
olds4life
May 4, 2011 09:57 AM
