sticky brakes.
Old Apr 23, 2011 | 05:51 AM
willj's Avatar
sticky brakes.
hi ,i have delta 88,and put new calipers on front , driver side was a mess ,all worn down and rotor was all deeply groved , so got new one, now all back together , and driver side is dragging , you have to step on gas to make it move ,it smokes if you go a half a mile , does not pull to the d/s ,but just does not seem to release all the way, thanks for any help ,will.
Old Apr 23, 2011 | 05:56 AM
I don't see you mention that you replaced or rebuilt the d/s caliper? Perhaps this is related to your original problem of that side having more wear than the other.
Old Apr 23, 2011 | 06:09 AM
76oldswarrior's Avatar
How old are the rubber brake lines to the caliper? I had the same problem on my truck. The rubber inside the line gets soft and the line will collapse and the fluid will nor return. I replaced the line and bleed the brakes and actually had little pieces of rubber come out while bleeding. That will keep the caliper from fully releasing.
Old Apr 23, 2011 | 06:19 AM
Lady72nRob71's Avatar
Some calipers need a small amount of grease in the tracks where they slide.
Did you clean those areas and grease them?
Also how old are the hoses? I once had a 30 year old hose on my Ford that developed an internal 'check valve' that would keep the pressure up once your foot is off the pedal. It wore the rotor down just like yours. It had a distict pull when braking, though.
Old Apr 23, 2011 | 06:26 AM
willj's Avatar
sticky brake
hi, thanks for the fast replys, i did put new caliper on d/s, when i bled it ,it bled very hard ,hard to get a good stream of fluid,thanks will.
Old Apr 23, 2011 | 06:34 AM
willj's Avatar
sticky brakes
also forgot to metion , the car has 150,000 on it ,i think the lines are all original, it is a 1989,thanks.
Old Apr 23, 2011 | 07:35 AM
Rickman48's Avatar
Replace both rubber lines - they're inexpensive! Should be the fix!
Don't know if you replaced both rotors, but you should. Aways replace things in pairs, when it comes to brakes, as it keeps the hydraulics operating the same.
Calipers .200 engaged due to a thinner rotor creates a side to side difference, and that thinner rotor will have more of a tendancy to warp when overheated!
Old Apr 23, 2011 | 08:43 AM
willj's Avatar
sticky brakes
went and got some rubber lines, its raining now ,when it stops will let ya know how it turns out ,thanks a million to all, will
Old Apr 23, 2011 | 09:06 AM
That indicates a problem somewhere!
Either hoses, or distribution block, or antilock system (if car has it).
Maybe master cyl, but I think that is not a common failure mode.
TIme for something to go bad!
Good rule of thumb. Besides, if you have bleed one side, it is not much harder to do the other.
Old Apr 24, 2011 | 02:04 PM
willj's Avatar
no more sticky brakes ,
was the rubber line , everyone was a big help, thank again ,was nice not to have to bring to a garage and pay $500. bucks , will.
yeahbuddy
Sep 9, 2010 03:24 PM
jensenracing77
Feb 23, 2009 05:52 PM
scrappie
Apr 1, 2008 08:28 AM
bandit600
Nov 15, 2006 06:24 AM
