Power to Manual Brakes
Old Feb 4, 2026 | 07:59 AM
MPSax's Avatar
Hi all,
Working on a 1969 442
Converted from PB to Manual
What parts numbers am I looking for to add the return spring and bumper for the brake pedal?
It looks like there should be a little tab too that the spring clips on- where could I find that?
I'm having a hard time finding them.
Old Feb 4, 2026 | 11:13 AM
Drum or disc?
Old Feb 6, 2026 | 09:04 PM
MPSax's Avatar
It was a power drum car, but I put in a manual 4 wheel disc set up.
Old Feb 7, 2026 | 06:20 AM
Then you need to use the correct manual 4wheel disc M/C for this aftermarket brake setup. Part number recommendations are meaningless since we have no idea of the calipers you used, the piston diameters in those calipers, or the matching M/C bore required to operate them properly. Who did you get the brakes from and what do they recommend for an M/C?
Old Feb 7, 2026 | 08:22 AM
MPSax's Avatar
I’m good with the MC
Since I now have manual brakes, I thought I needed the return spring and bumper under the dash on the pedal assembly, that’s what I’m looking for.
Old Feb 7, 2026 | 09:42 AM
69CSHC's Avatar
Originally Posted by MPSax
1969 Oldsmobile 442 -- Daily Driver -- 550hp 477 / TH400 / 3.23 Gears POSI
That's one helluva daily driver, love it.
Surprised you switched to manual disc (honestly didn't realize this was an option back then). My first a 67 Cutlass Coupe was manual drum and definitely kept you alert while driving in modern traffic back in 1987. Years later my 66 442 came power assist drum and it stopped great. But it also came with 1/2 your power.
Old Feb 7, 2026 | 10:52 AM
It wasn't, at least not four wheel disc brakes. Actually manual front disc brakes were a mid-year option on 1969 W30s.
Old Feb 7, 2026 | 11:49 AM
MPSax's Avatar
My olds 4 drum PB stopped the car like a dream. Could lock up the tires.
unfortunately working out bugs on the manual 4 disc kit from The Right Stuff. Very poor stopping performance.
I don’t have enough vacuum for reliable power brakes but I should still be able to lock up the tires with manual brakes. Frustrating.
I think I found the return spring and stop from summit. That won’t help any but at least get under the dash correct.
I am swapping to another manual disc/disc MC. I think I hurt the one with the kit pushing the piston in too far bench bleeding.
Old Feb 7, 2026 | 12:01 PM
Once again, the M/C bore must be correct for the braking system used. I've found that nearly none of the aftermarket brake kit providers (including big name ones) have a clue about correctly sizing or matching parts. For starters, your manual M/C should be no larger than 1" bore, possibly even 15/16" to get the necessary pedal pressure. Of course, the risk in downsizing the bore is having enough pedal throw to provide sufficient volume to the wheels. And I ASSUME you have the pushrod in the upper hole in the pedal to get the correct pedal ratio.
Old Feb 7, 2026 | 12:37 PM
MPSax's Avatar
It’s a 1inch bore size. Mounted to top pin location.
I’m not even really sure how you could mount it to the bottom pin since the angle is straight back without the booster.
Old Feb 7, 2026 | 01:11 PM
Run to Rund's Avatar
I assume you have a provision to ensure that the pushrod can't fall out of the master cylinder cup, such as this reproduction from Inline Tube.
Old Feb 7, 2026 | 03:48 PM
Loaded68W34's Avatar
Get a 7/8" bore master cylinder and be done, or change your plans entirely and put on a hydraboost system. That is unless you are running manual steering as well.
Old Feb 7, 2026 | 04:15 PM
MPSax's Avatar
manual steering, no PS pump!
I don’t mind the pedal effort, I just feel they should grab more. Where could I find a 7/8” bore disc/disc MC?
Old Feb 7, 2026 | 04:16 PM
MPSax's Avatar
The push rod that I have is smooth, no indent.
Old Feb 7, 2026 | 05:33 PM
Between that and the brakes, I guess you won't be loaning the car to your wife.
Old Feb 7, 2026 | 05:44 PM
Are you going for a factory look, or aftermarket on the master cylinder?
You can buy a stock-is style (no bleeders) like the one below from many vendors
https://www.ecklers.com/camaro-gm-co...MaAmfMEALw_wcB
Or you could buy an aftermarket version like the wilwood below
https://www.summitracing.com/parts/w...0aApmuEALw_wcB
Old Feb 7, 2026 | 06:00 PM
MPSax's Avatar
Stock appearing would be preferred for now -
I am replacing this currently- just finished painting it and it's on the workbench, but suppose I could switch to a 7/8 bore. Would it be a noticeable difference?
https://www.summitracing.com/parts/RSD-DBMC05
In the picture for Ecklers, it shows disc/disc as a possibility but in the description it says
For Disc/Drum or Drum/Drum Applications
Old Feb 7, 2026 | 06:02 PM
MPSax's Avatar
For anyone curious about the original question- this is the spring and stops I'm ordering.
They should be what I need since I no longer have the booster to push the pedal up.
Currently the pedal will return fine without it, but I think it is right to have these...
Old Feb 7, 2026 | 06:04 PM
MPSax's Avatar
lol I'm barely confident driving it myself!
Old Feb 7, 2026 | 06:29 PM
[QUOTE=MPSax;1668880]
[QUOTE]
I saw that and I believe it is a miss-print. Should read Disc/ Drum or Disc/ Disc. A Drum/ Drum mastercylinder would not have a larger front reservior as seen in the photo you posted. Front and rear reservior would be the same size for 4-wheel drums. You could call Ecklers to be sure though. Are you running a Disc/ Disc proportioning valve? You may want to run a drum style distribution block with an adjustable proportioning valve on the rear line. It will take some road testing to fine tune, but will keep the back brakes from locking up before the front.
Old Feb 8, 2026 | 08:54 AM
With a smooth pushrod, you could force onto it an internal star washer that grips it tightly, and then use the Inland Tube retaining "cup". I would sure use something. Drag racer Ken Etter had a bad accident a few years ago when the pushrod came out of his master cylinder and he had no brakes.
craig442
Jun 26, 2024 08:19 PM
Chris6542
Apr 30, 2020 06:39 AM
rr480
Oct 8, 2012 05:02 PM
rr480
Brakes/Hydraulic Systems
Sep 25, 2012 11:19 AM
Southern_Hospitality
Mar 19, 2008 09:39 PM
