Good Morning, I have to replace my power booster (again). I am thinking of doing an aftermarket one like the one linked. I am curious about the different diameter sizes. Most seem either 8 inches or 9 inches. What difference would the diameter make....
I should add, I will most likely need to add a vacuum pump, with my cam I only get about 10-11 inches of vacuum.
Timothy,
The power of the booster is determined by the area of the diaphragm.
So, compared to a factory 11" booster, the 9" has a third less power and the 8" has 47% less power.
If you need a smaller booster for clearance, some use a dual-diaphragm 8" which has about the same power that the 11" does. That looks like the one you linked.
Gary
Reason: add information
Ditch the vacuum pump and booster and get a hydroboost. Running off the PS pump pressure makes this insensitive to engine vacuum and it's much smaller.
