Power Brakes and Vacuum
Old May 2, 2020 | 08:57 AM
Roger60's Avatar
Four wheel discs, all bled properly, no issues there. Good high pedal with engine off. Start engine and the power booster has the pedal going practically to the floor.
My question : Is there any way to regulate the vacuum to the booster? I have tried vacuum from both the manifold and the back of the carb. Thanks.
Old May 2, 2020 | 09:19 AM
70sgeek's Avatar
'72 Cutlass ragtop
Electric vacuum pump or a vacuum canister are 2 potential options - the electric pump would be a complete substitute for engine vacuum (provides a constant 18-20 lbs), the vacuum canister would simply store additional vacuum coming off the engine as kind of a supplement.
I had a really good electric pump (I think it's called a Bandit), but the downside of using one is if the fuse in its power feed line blows, you lose your vacuum supply, i.e. your brakes basically disappear. So I got paranoid and now the Bandit is back in its box on my shelf for now.
Old May 2, 2020 | 10:02 AM
Your problem isn't "regulating" vacuum. Your problem is that the pushrod from the pedal to the booster is too long and is activating the booster air admittance valve. Readjust the pushrod. Be sure it is in the lower of the two holes in the brake pedal arm. If that doesn't fix the problem, then the valve in the booster itself is bad.
ivmachine
Brakes/Hydraulic Systems
Aug 28, 2018 09:09 PM
Don Roberto
23
Feb 28, 2018 01:49 PM
rmoths
Nov 5, 2013 05:00 PM
Raydermiike
Sep 4, 2013 03:00 PM
olds68
Feb 12, 2009 08:27 PM
