Booster Diameter Question
Old Apr 12, 2023 | 05:23 AM
timothypaul's Avatar
Good Morning, I have to replace my power booster (again). I am thinking of doing an aftermarket one like the one linked. I am curious about the different diameter sizes. Most seem either 8 inches or 9 inches. What difference would the diameter make....
I should add, I will most likely need to add a vacuum pump, with my cam I only get about 10-11 inches of vacuum.
Thank you.... :-) Timothy
https://www.summitracing.com/parts/l...=true#overview
Old Apr 12, 2023 | 05:46 AM
VC455's Avatar
Barely Registered
Timothy,
The power of the booster is determined by the area of the diaphragm.
So, compared to a factory 11" booster, the 9" has a third less power and the 8" has 47% less power.
If you need a smaller booster for clearance, some use a dual-diaphragm 8" which has about the same power that the 11" does. That looks like the one you linked.
Gary
Old Apr 12, 2023 | 06:28 AM
Ditch the vacuum pump and booster and get a hydroboost. Running off the PS pump pressure makes this insensitive to engine vacuum and it's much smaller.
Old Apr 12, 2023 | 01:51 PM
Love to do that Joe, but “eeck” that is way out of my budget….
Old Apr 12, 2023 | 02:01 PM
Which one are you looking at? This one is $475.
If you want to spend a little fabrication and scrounging effort, you can adapt a common hydroboost from a GM one ton pickup using these brackets.
Old Apr 12, 2023 | 02:05 PM
Oh wow - that is definitely reasonable. I was looking at some on Summit that were starting at $ 850 and up.
Roger60
Brakes/Hydraulic Systems
May 2, 2020 10:02 AM
Jhucks03
Apr 4, 2020 04:17 PM
Corswiki
Apr 10, 2019 07:29 PM
Don Roberto
23
Feb 28, 2018 01:49 PM
Tangovino
Feb 5, 2009 11:00 PM
