1968 Delta Drums
Old Jan 31, 2023 | 10:23 AM
VisbleBoatmobile's Avatar
As Seen on Roadkill
1968 Delta Drums
Currently on the hunt for drums for my 68 delta 88 town sedan
A part number? Used but good?
Anything is better than the warped mess that I have on it right now
All I can tell right now is that it is not 9 inch brakes
They look to be 11 or maybe 12?
Old Jan 31, 2023 | 11:09 AM
Have you taken the drums into a shop to see if they can be turned?
Old Jan 31, 2023 | 12:14 PM
^^^THIS! Drums for these cars are pretty much unobtanium. Craig at MobileParts may have more now - at one point I had cleaned him out of all the NORS ones he had. The specs on the brakes are listed at the end of Section 5 in the 1968 Chassis Service Manual. The 1968 Delta used 11" x 2.75" front brakes and 11" x 2" rear brakes.
I should add that as rare as it is to find a place to turn drums anymore, and given the difficulty in obtaining replacement drums for this car, I STRONGLY suggest that you take them to a reputable, full-service automotive machine shop to be turned.
Old Jan 31, 2023 | 01:05 PM
As Seen on Roadkill
Yeah and the hub face has been bent. I assume that someone tried to beat out the hubs/studs with a hammer and bent the front drums. I’m going to try and convert it to 11x2s in the front and use Chevy 11x2 drums this weekend
Old Jan 31, 2023 | 01:35 PM
That's a REALLY bad idea. Aside from the obvious reduced braking force and screwed-up front/rear brake bias, think for a minute how you would convert those. The drum is still 2" deep. The backing plates are sized for 2.75" shoes, so the 2" shoes would be 3/4" out of the drums, leaving only 1.25" of engagement. If you think you're going to put the Chevy backing plates on the Olds spindles, think again. The Chevy spindles are completely different. Nothing from the suspension or steering interchanges. Oh, and Impalas of that vintage use a 4.75" wheel bolt pattern, not 5" like the Olds. And no, the Chevy hubs won't fit on the Olds spindles. The wheel bearings are different diameters.
Old Jan 31, 2023 | 03:11 PM
Vistabrat72's Avatar
As a possible solution, Kanter Auto may be able to help. I would speak to them to verify for sure their product will fit. They do not look like the original 'bell' style drums, in fact, they remind me of the finned drums used on some late 1960's full-size Dodge. Try them if Craig at Mobile has no O/E ones.
https://www.kanter.com/i-30559268-br...e%3DOLDSMOBILE
Old Feb 1, 2023 | 04:36 AM
If you can get replacements from Kanter go that way. Even if they're drop forged Chinesium.
Old Feb 1, 2023 | 05:44 AM
As Seen on Roadkill
And that was my next question. I wasn't sure if it used the 4.75 lug pattern. I'm definitely going to go with the ones from Kanter granted they fit. Below is a few pics of my drums just to verify
Passenger
Driver with speedo cable thing
turley68delta88
Jun 8, 2017 05:52 AM
orange442
Jan 3, 2012 10:22 AM
trainfixer2
Oct 12, 2009 02:44 PM
RAMOS_ANT
Sep 1, 2009 08:34 PM
