Pushrod length
Old Sep 2, 2022 | 07:41 AM
69greenmachine's Avatar
Pushrod length
Hi !
I was inquiring to see what is the pushrod length for a 69 442 power front/rear drum car .
thank u !
Old Sep 2, 2022 | 09:54 AM
I ASSUME you are talking about the pushrod between the power booster and master cylinder?
There are only two lengths, short and long. The 1967-up cars with dual circuit master cylinder all used the short pushrod.
Old Sep 2, 2022 | 10:59 AM
Yes that is exactly the answer I was looking for .
I appreciate your time and response. I just purchased a new power booster which has the short rod installed and came with the long one as well . Just waiting for a back ordered master cylinder and was curious to see which one is required before taking old M/C off .
Thank you again !
Old Sep 2, 2022 | 11:07 AM
Thank you again !
If you are getting a correct replacement M/C, it should have the matching shallow hole in the piston. Some aftermarket M/C come with the deep hole and a spacer that you insert if you have a booster with the short pushrod. Just note the hole in the new M/C before installing it.
Old Sep 2, 2022 | 11:40 AM
valuable information!!!
Thank you !
I love learning new stuff every day .
HarrySlother
Aug 18, 2021 09:46 PM
Del70
Mar 9, 2016 04:26 PM
LX89mustang
Sep 27, 2012 07:27 AM
NastyNate6695
Drivetrain/Differentials
Dec 30, 2011 07:52 PM
Cr099
Jul 28, 2010 10:21 PM
