1970 Brake Distribution Block
I am currently trying to bleed the brakes on my 1970 Rallye. The entire system is new. I was having trouble bleeding the rear brakes and thought maybe the switch in the distribution block had become un-centered. So I used a ohm meter to see if the switch to the brass block had any resistance. It does so I assume that means the switch valve is not centered. So I removed the switch to try and re-center the switch and some fluid can out. I'm I correct in thinking this is not good. If so, how hard is it to rebuild? I block is new from inline tube but I bought it over two years ago so I do not think they will replace it.
There is also a rebuild kit available here.
I realize there are many methods to bleeding brakes, and one should use the method they prefer, but I want to share my experience with bleeding a '70 442. I use the power bleeder, which is a pump-up, pressurized system. The most difficult part is clamping the sealing cap to the top of the master cyclinder.
Once that is done the system is pressurized to about 10psi. I do nothing to the brake distribution block and I've not had problems with it gettig off-center.
Each wheel bleeds very well; I can run a quart of fluid when flushing through the entire system in a very short time, and it is a one-person set-up. Bleeding brakes is something I enjoy doing now, while in the past it was a nightmare. Just this past week, I've flushed the brake system in two of my Classics, and plan on doing my Tundra in the next few days.
As Joe P points out, the rebuild kit is inexpensive, and the task of rebuilding the distribution block is not difficult. The worst part is getting the darn thing off the frame member.
Hope this information helps....
