72 combination valve fault switch
If the combination valve fault switch is replaced, will it be necessary to bleed the lines? This is just removing the old switch and replacing with a new one and not doing anything else. Based on the cut away diagram it appears that the region where the switch goes is sealed off from the front and back circuits.
I have to remove the switch to jiggle the piston. My light goes on and off with varying brightness that started after I flushed the brakes. I let it go for awhile to see if it would go out permanently with use but it didn't. I figure for about $10 I might as well put a new one in there since I'm messing with it.
