1972 Front Disc - Stainless Caliper Hose
Anyone use these flexible stainless steel brake caliper hose lines?
https://www.summitracing.com/parts/rsd-fh06s
Looking to swap out the 52 year old rubber lines on a 1972 Olds 442 with front disc brakes.
No, just can't justify the expense difference when the functionality is the same. I'd rather spend money on other things. Beneath the stainless sheath the line is still rubber.
1972 OLDSMOBILE CUTLASS Dorman H73242 Dorman Hydraulic Brake Hoses | Summit Racing
I've used similar braided stainless brake hoses with no issues. Be sure they are AN-3 with teflon liners. If possible, get the ones that are DOT approved. Many are not. That doesn't mean that they are any better or worse, just that the vendor didn't want to pay for the certification. The problem will come if you ever have an accident and the insurance company finds out that you didn't have DOT-approved brake hoses. Hilarity ensues.
scubastever
Brakes/Hydraulic Systems
Sep 24, 2010 11:33 AM
