Weird noises!?!
Old Oct 10, 2018 | 06:35 PM
Tsiakos1987's Avatar
Weird noises!?!
Hey guys I need some expertise here...I have a 72 supreme with front drums. It’s making a weird whooshing noise as I drive. I changed the drums, shoes, wheel bearings and I just double checked all my work today . It almost sounds like the wheel is loose so I changed the rims (went from mags back to the ss2). Still no luck. Almost feels loose up front. Could it just be the shoes Mateing to the drum? Thanks! -Chris
Old Oct 10, 2018 | 06:43 PM
lshlsh2's Avatar
71 cutlass convertible
Wheel bearings?
Old Oct 10, 2018 | 06:49 PM
Changed them already
Old Oct 11, 2018 | 02:32 AM
Ozzie's Avatar
"Wooshing" is difficult to understand. If you could post a small audio clip it would help.
Old Oct 11, 2018 | 04:52 AM
It sounded like this "woooooooooooooooooooooooooooooosh."
Old Oct 11, 2018 | 02:52 PM
76olds's Avatar
Hookers under Hood
Sounds like either the heater box vacuum vent leak coming from under the dash or the brake booster diaphragm is leaking. How does the brake pedal feel ? Does the pedal go down past the gas pedal ?
Eric
Tiberian Fiend
Nov 24, 2018 02:49 PM
Scarebird
Oct 8, 2018 10:28 AM
Gary M
Body work
Mar 31, 2018 03:49 PM
plonka
Nov 17, 2013 02:57 PM
Olds Scott
Feb 27, 2013 05:26 AM
