Weird noises!?!
Weird noises!?!
Hey guys I need some expertise here...I have a 72 supreme with front drums. It’s making a weird whooshing noise as I drive. I changed the drums, shoes, wheel bearings and I just double checked all my work today . It almost sounds like the wheel is loose so I changed the rims (went from mags back to the ss2). Still no luck. Almost feels loose up front. Could it just be the shoes Mateing to the drum? Thanks! -Chris
Sounds like either the heater box vacuum vent leak coming from under the dash or the brake booster diaphragm is leaking. How does the brake pedal feel ? Does the pedal go down past the gas pedal ?
Eric
Eric
