Disc brake conversion/ brake lines
Old May 13th, 2018, 01:49 PM
Doorman1970's Avatar
just installed a disc brake Conversion on my 72 cutlass and at the point of getting the lines hooked up but now thinking that I should just replace those as well since I would have to modify them anyway , any advice as to buy a prebent kit vs making them my self from scratch. I’d like them to look good but not sure if they make the proper kit without modifying. My car was a drum/drum and has a distribution valve on the frame now but the new kit came with a new prop valve mounted to the master. Any advice / ideas welcome !
Doorman1970 is offline
Old May 13th, 2018, 03:39 PM
Dave26's Avatar
Take a look at “The Right Stuff” or “Summit’s” website, they should all of the pre-bent lines you need.
Dave26 is online now
Old May 13th, 2018, 05:25 PM
Been looking at those but from what I understand the factory setup didn’t have the prop valve on the master so I’m not sure if they have the correct kit without modifying I’m going to call their tech line tomorrow
Old May 13th, 2018, 06:27 PM
Dave26's Avatar
They do have the lines that go from the prop valve on the master. I did the conversion
Old May 13th, 2018, 06:44 PM
Thanks I’ll check it out
Old May 16th, 2018, 08:21 AM
'87 Delta 88 Royale
rustyroger's Avatar
Make your own with cupro/nickel brake tubing, then never worry about replacing them again.
Roger.
rustyroger is offline
Mocephus
October 1st, 2021 09:45 AM
68442Convertible
Brakes/Hydraulic Systems
June 8th, 2016 08:15 PM
Maverick
June 26th, 2013 08:21 AM
68droptop
March 31st, 2009 06:10 PM
Want-A-Vert
January 4th, 2007 07:19 AM
Quick Reply: Disc brake conversion/ brake lines
