Manual Brake Conversion - ClassicOldsmobile.com
LinkBack Thread Tools Search this Thread
Old April 16th, 2018, 11:00 AM   #1
TripDeuces's Avatar
I have a 66 Cutlass that originally had a single bowl master cylinder with a booster. I'm not sure how many inches of vacuum my engine will pull so I'm leaning toward a manual dual bowl master cylinder set up with a proportioning valve for front to rear bias using disc brakes at each corner.
What advice can anyone offer about this swap? What if any pitfalls are there? Installation concerns etc. that I should be aware of?
Thanks for the help, G
TripDeuces is online now   Reply With Quote
Old April 16th, 2018, 02:02 PM   #2
69455's Avatar
After market Wilwood
You can run a manual small piston master cyl with large piston calipers for a good feel.
Proportion valve on the rear.
Almost as power brake feel.
69455 is offline   Reply With Quote
Old April 16th, 2018, 02:18 PM   #3
The only thing the brakes care about is the piston diameter. If you want the Wilwood bling, go for it. Otherwise, a factory replacement M/C works exactly the same. All that matters is the piston diameter. M/C bolts to the top two bolts that held the booster. Run nuts down on the other two to retain the pedal assembly to the firewall. Connect the M/C pushrod to the top hole on the brake pedal. Done. This is not difficult.
joe_padavano is offline   Reply With Quote
Old April 16th, 2018, 05:33 PM   #4
HX3
HX3's Avatar
My '67 442 uses a Wilwood adjustable proportioning valve mounted along side of MC to control front/rear brake bias. MC is a corvette style with a 1 inch bore. Front brake setup is '79 to '81 camaro/firebird disk and rear brakes are original drum for '59 9.3 inch Olds rear end. Even with the straight front axle, braking works well once brake bias is dialed in.
67 Olds 442 Gasser
HX3 is offline   Reply With Quote
Old April 16th, 2018, 06:17 PM   #5
young olds's Avatar
Quote:
67 Olds 442 Gasser
I have the same set up it seems on my 66. Master for a C3 corvette with four wheel manual disk and a wilwood adjustable proportioning valve. Brakes are just one of those generic a body kits
young olds is online now   Reply With Quote
Old April 17th, 2018, 08:42 AM   #6
TripDeuces's Avatar
Good stuff, thank you all.
Old Yesterday, 10:31 AM   #7
Be sure to get and use the derby hat pushrod retainer.
Inline tube reproduces it, #12439
Run to Rund is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
POSSIBLE disc brake conversion for disc brake cars 67-70 Mocephus Eighty-Eight 11 November 28th, 2016 08:30 AM
Manual to Power Brake Conversion Cincinnati Rick Brakes/Hydraulic Systems 10 September 24th, 2015 11:17 AM
Disc Brake Conversion - Brake Line Change ? Maverick Brakes/Hydraulic Systems 6 June 26th, 2013 08:21 AM
53 olds manual to power brake conversion va88 Brakes/Hydraulic Systems 3 July 29th, 2007 12:41 PM
Manual-to-Power Brake Conversion Project Kahuna Brakes/Hydraulic Systems 7 June 17th, 2007 10:51 AM
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
All content Copyright © 2017 by Internet Brands, Inc.
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
