Manual Brake Conversion
Old April 16th, 2018, 11:00 AM
TripDeuces's Avatar
I have a 66 Cutlass that originally had a single bowl master cylinder with a booster. I'm not sure how many inches of vacuum my engine will pull so I'm leaning toward a manual dual bowl master cylinder set up with a proportioning valve for front to rear bias using disc brakes at each corner.
What advice can anyone offer about this swap? What if any pitfalls are there? Installation concerns etc. that I should be aware of?
Thanks for the help, G
TripDeuces is offline
Old April 16th, 2018, 02:02 PM
69455's Avatar
After market Wilwood
You can run a manual small piston master cyl with large piston calipers for a good feel.
Proportion valve on the rear.
Almost as power brake feel.
69455 is offline
Old April 16th, 2018, 02:18 PM
The only thing the brakes care about is the piston diameter. If you want the Wilwood bling, go for it. Otherwise, a factory replacement M/C works exactly the same. All that matters is the piston diameter. M/C bolts to the top two bolts that held the booster. Run nuts down on the other two to retain the pedal assembly to the firewall. Connect the M/C pushrod to the top hole on the brake pedal. Done. This is not difficult.
joe_padavano is offline
Old April 16th, 2018, 05:33 PM
HX3
HX3's Avatar
My '67 442 uses a Wilwood adjustable proportioning valve mounted along side of MC to control front/rear brake bias. MC is a corvette style with a 1 inch bore. Front brake setup is '79 to '81 camaro/firebird disk and rear brakes are original drum for '59 9.3 inch Olds rear end. Even with the straight front axle, braking works well once brake bias is dialed in.
67 Olds 442 Gasser
HX3 is offline
Old April 16th, 2018, 06:17 PM
young olds's Avatar
67 Olds 442 Gasser
I have the same set up it seems on my 66. Master for a C3 corvette with four wheel manual disk and a wilwood adjustable proportioning valve. Brakes are just one of those generic a body kits
young olds is online now
Old April 17th, 2018, 08:42 AM
TripDeuces's Avatar
Good stuff, thank you all.
Old April 18th, 2018, 10:31 AM
Run to Rund's Avatar
Be sure to get and use the derby hat pushrod retainer.
Inline tube reproduces it, #12439
Run to Rund is offline
Mocephus
October 1st, 2021 09:45 AM
Cincinnati Rick
Brakes/Hydraulic Systems
September 24th, 2015 11:17 AM
Maverick
June 26th, 2013 08:21 AM
va88
July 29th, 2007 12:41 PM
Kahuna
June 17th, 2007 10:51 AM
Quick Reply: Manual Brake Conversion
