New booster
Old November 12th, 2017, 06:46 AM
rickbmac's Avatar
New booster
I purchased a power booster. The rod on the pedal side seems to be short. Does there generally need to be an extension? Also, does the provided dust cover between the booster and firewall need to be cut down?
rickbmac is offline
Old November 13th, 2017, 03:13 AM
rickbmac's Avatar
Has this issue been covered in another post? If so, location?
rickbmac is offline
Old November 13th, 2017, 03:17 AM
What brand/pn booster did you buy? The rod should be long enough to connect to the lower hole and allow the pedal to rest against the return stop.
oldcutlass is online now
Old November 13th, 2017, 07:56 AM
oddball's Avatar
Is the dust cover the white plastic tube? It crunches a bit and the small end gets smooshed into the firewall hole. It'll fit.
Some boosters got manufactured with short rods for custom/altered applications. I picked one up with a nice discount. You can get an extension from folks like MBM.
http://piratejack.net/universal-4-3-...rod-extension/
oddball is offline
Old November 13th, 2017, 07:57 AM
rickbmac's Avatar
Purchased not 100 percent sure of applications. Maybe for Nova. Also, booster to master cylinder pin incorrect diameter.
rickbmac is offline
Old November 13th, 2017, 07:58 AM
rickbmac's Avatar
Bolts right up to firewall
rickbmac is offline
Old November 15th, 2017, 08:54 AM
rickbmac's Avatar
Contacted Cardone. Tech identification was 54-8111
rickbmac is offline
Old November 15th, 2017, 09:29 AM
That pn is not valid, yours should be 54-71106 fir a 72 Cutlass. It looks like the one in your pic was connected to the top hole on your brake pedal by the way the plastic cover is crushed up.
http://www.cardone.com/Products/Prod...ear=1972&info=
The Bug Man
Brakes/Hydraulic Systems
October 18th, 2014 07:04 AM
zodiacblueS
44
October 12th, 2014 03:22 PM
zodiacblueS
May 21st, 2012 03:45 PM
Del70
June 13th, 2011 03:41 AM
w-30dreamin
May 10th, 2010 09:49 AM
Quick Reply: New booster
