New booster
Old Nov 12, 2017 | 06:46 AM
rickbmac's Avatar
New booster
I purchased a power booster. The rod on the pedal side seems to be short. Does there generally need to be an extension? Also, does the provided dust cover between the booster and firewall need to be cut down?
Old Nov 13, 2017 | 03:13 AM
rickbmac's Avatar
Has this issue been covered in another post? If so, location?
Old Nov 13, 2017 | 03:17 AM
What brand/pn booster did you buy? The rod should be long enough to connect to the lower hole and allow the pedal to rest against the return stop.
Old Nov 13, 2017 | 07:56 AM
oddball's Avatar
Is the dust cover the white plastic tube? It crunches a bit and the small end gets smooshed into the firewall hole. It'll fit.
Some boosters got manufactured with short rods for custom/altered applications. I picked one up with a nice discount. You can get an extension from folks like MBM.
http://piratejack.net/universal-4-3-...rod-extension/
Old Nov 13, 2017 | 07:57 AM
rickbmac's Avatar
Purchased not 100 percent sure of applications. Maybe for Nova. Also, booster to master cylinder pin incorrect diameter.
Old Nov 13, 2017 | 07:58 AM
rickbmac's Avatar
Bolts right up to firewall
Old Nov 15, 2017 | 08:54 AM
rickbmac's Avatar
Contacted Cardone. Tech identification was 54-8111
Old Nov 15, 2017 | 09:29 AM
That pn is not valid, yours should be 54-71106 fir a 72 Cutlass. It looks like the one in your pic was connected to the top hole on your brake pedal by the way the plastic cover is crushed up.
http://www.cardone.com/Products/Prod...ear=1972&info=
The Bug Man
Brakes/Hydraulic Systems
Oct 18, 2014 07:04 AM
zodiacblueS
44
Oct 12, 2014 03:22 PM
zodiacblueS
May 21, 2012 03:45 PM
Del70
Jun 13, 2011 03:41 AM
w-30dreamin
May 10, 2010 09:49 AM
