dot
Old March 28th, 2016, 03:37 PM
rodan's Avatar
dot
Ok guys I have a 69 cutlass,front disk brakes. I just changed the brake booster and master cylinder. What dot fluid do I use 3 or 5?
rodan is offline
Old March 29th, 2016, 10:39 AM
hookem horns's Avatar
DOT3 or DOT4 mostly likely, DOT5 is silicone based and not compatible with the old stuff still in the lines.
hookem horns is offline
Old March 29th, 2016, 11:18 AM
mpolds's Avatar
Exactly...
DOT 3 or DOT 4 (higher cleansing agents -- actually much better -- a little bit more expensive)....
Do NOT NOT use DOT 5 -- that is silicone brake fluid -- and NOT NOT
compatible at all -- only for use when the system is fully flushed and
prepared specifically for DOT 5 Brake Fluid....
mpolds is offline
Old March 29th, 2016, 02:21 PM
rodan's Avatar
dot
Thanks guys . i thought it was dot 3 ,but when you start reading you get so many different answers, so I came to the wright place thanks again.
rodan is offline
Old March 29th, 2016, 04:33 PM
72 Olds CS
RetroRanger's Avatar
the synthetic stuff i just bought was DOT 3&4 compatible !!!! FYI
RetroRanger is offline
Sampson
Brakes/Hydraulic Systems
18
April 9th, 2014 03:32 PM
droldsmorland
March 3rd, 2014 05:15 PM
DRXOLDS
October 12th, 2013 10:17 PM
oldsmobiledave
October 4th, 2013 05:26 PM
gunsxofxsummer
June 5th, 2010 10:20 AM
Quick Reply: dot
