dot
Old Mar 28, 2016 | 03:37 PM
rodan's Avatar
dot
Ok guys I have a 69 cutlass,front disk brakes. I just changed the brake booster and master cylinder. What dot fluid do I use 3 or 5?
Old Mar 29, 2016 | 10:39 AM
hookem horns's Avatar
DOT3 or DOT4 mostly likely, DOT5 is silicone based and not compatible with the old stuff still in the lines.
Old Mar 29, 2016 | 11:18 AM
mpolds's Avatar
Exactly...
DOT 3 or DOT 4 (higher cleansing agents -- actually much better -- a little bit more expensive)....
Do NOT NOT use DOT 5 -- that is silicone brake fluid -- and NOT NOT
compatible at all -- only for use when the system is fully flushed and
prepared specifically for DOT 5 Brake Fluid....
Old Mar 29, 2016 | 02:21 PM
rodan's Avatar
dot
Thanks guys . i thought it was dot 3 ,but when you start reading you get so many different answers, so I came to the wright place thanks again.
Old Mar 29, 2016 | 04:33 PM
RetroRanger's Avatar
72 Olds CS
the synthetic stuff i just bought was DOT 3&4 compatible !!!! FYI
Sampson
Brakes/Hydraulic Systems
18
Apr 9, 2014 03:32 PM
droldsmorland
Mar 3, 2014 05:15 PM
DRXOLDS
Oct 12, 2013 10:17 PM
oldsmobiledave
Oct 4, 2013 05:26 PM
gunsxofxsummer
Jun 5, 2010 10:20 AM
