Who wanted to see my brake setup?
Old Oct 7, 2009 | 09:23 PM
gearheads78's Avatar
car guy
About two weeks ago one of you asked me if I had any pics of the brakes installed without wheels. I didn't but cleaning up last weekend for Goodguys I had them off so here you go.
Old Oct 7, 2009 | 09:54 PM
delmontcrusier's Avatar
67 heavy metal
hooo weee look at you disks all aroundI am jelous I still have drums all around
Old Oct 7, 2009 | 11:52 PM
svnt442's Avatar
What calipers are those front ones?
Old Oct 8, 2009 | 07:18 AM
car guy
started out life on a 2007 Corvette
Old Oct 8, 2009 | 01:40 PM
svnt442's Avatar
Ok........spill it.
Old Oct 8, 2009 | 01:58 PM
car guy
Ok........spill it.
Cliff notes....
-Buy used brakes off Corvettes.com forum
-order Kore3 mounting brackets
-take apart calipers
-file, sand and hand smooth CORVETTE and casting flash off caliper
- drop off at CNC shop for OLDSMOBILE script to be milled
-spend 6-7 hours with high heat tape and x-acto knife masking letters
-drop off at powder coater
-10-12 hours with a tiny dremel and x-acto knife cutting powder coating and tape from lettering
-assemble calipers and install on car
I have as much time and effort in these brakes as anything else on the car but its fun answering the "Wherd ja order dem from?" questions I get at shows.
Old Oct 8, 2009 | 02:37 PM
svnt442's Avatar
Are the letters raised or depressed in the metal? I really can't tell from the pic.
Old Oct 8, 2009 | 02:51 PM
car guy
Countersunk about 1/8" deep
Old Feb 22, 2011 | 07:28 AM
Jhall64's Avatar
Hubs and spindles
Gearhead,Did you use the stock Hub and drum spindle?
Old Feb 22, 2011 | 08:30 AM
car guy
Yes I did. Tobin at Kore3 sold me the brackets
Old Mar 24, 2011 | 09:23 PM
Wyze's Avatar
What else did you need???
Old Mar 25, 2011 | 06:53 AM
car guy
The brackets from Kore3 everything else is all the brake parts form the Corvette donor car.
Old Mar 25, 2011 | 09:28 PM
svnt442's Avatar
So both the front and rear brackets came from Kore3.....in Australia?
Old Mar 26, 2011 | 07:31 AM
car guy
Rear are mostly LS1 off a 02 Trans Am. I had to make some spacers to get it all to work. They make some kits but I just went my own way on the rear. Kore3 is not down under. They are in OR
http://www.kore3.com/index.php
Old Mar 27, 2011 | 01:03 AM
svnt442's Avatar
So what's with the "DBA" stuff? It just looked to me like it was down under.
Old Mar 27, 2011 | 08:15 AM
car guy
Looks like a product line that Tobin has picked up.
Old Jun 4, 2011 | 04:54 PM
frisco442's Avatar
I really like the "OLDSMOBILE." Its all about the custom things that you dont notice right away. Stuff like that really sets you apart. well done amigo
Old Jun 4, 2011 | 08:39 PM
Redog's Avatar
I like, nice job!!
I did something simlar with my Alero. complete 98-02 F Body set-up in the front and 05 Pontaic GXP in the rear.
No powdercoat on the calipers or brackets, just a rattle can here. Rotor hat is powdercoated
Old Oct 17, 2011 | 02:23 PM
Wyze's Avatar
I love these brakes!!!!!!!!!
I need more info!!!!!!
Old Oct 17, 2011 | 02:39 PM
Redog's Avatar
My front set-up is 98-02 Camaro calipers and brackets and 00-05 Impala rotors which are 12 inch rotors. Camaro and Corvette calipers are pretty damn close to the same thing. The Vette Calipers have 22% better clamping force. A lot of "F" body guys swap the Vette calipers. They require 16 inch wheels.
Pontaic Grand Prix GXP brakes require 17 inch wheels.
Gearhead, What size wheels are you running? I'm wondering if I could swap double piston calipers on the front of my Delta
malibu406
Brakes/Hydraulic Systems
16
Feb 15, 2010 08:11 AM
Wilson05
Dec 11, 2009 02:33 AM
cardinals25
Mar 24, 2009 06:39 AM
OldsMotion
Jul 12, 2007 12:45 PM
