Vibration when braking
Old Apr 17, 2025 | 06:32 AM
  #81
72455's Avatar
1972 U code Supreme
Originally Posted by cjsdad
As far as painting, any kind of gloss paint will reduce the heat dissipation properties of the brake drums. I think Eastwood sells a natural cast iron color so they would look natural but not rust. Maybe it is available in satin or flat finish.
I never thought about the paint being a deterrent to proper heat dissipation. I think for now I'll leave them as is and maybe paint them at a later time.
Old Apr 17, 2025 | 06:46 AM
  #82
Correct about heat dissipation. If you don't paint them now, you will never paint them - unless you intend to spend significant amount of time removing all surface rust, oil, residues, etc. from the outside surface prepping them for paint which, IMO, will eventually wear off. Heat needs a surface to escape, DIY painting hinders that ability & helps to ensure the paint lifts from the metal where the underlying rust develops & accumulates, causing the paint to lift.
Old Apr 17, 2025 | 08:08 AM
  #83
jaunty75's Avatar
Painting brake drums is like painting the inside of the gas tank. No one will ever see it, so why do it?
People sometimes ask about the term "over-restored" when referring to an old car. This is an example of that. They weren't painted at the factory.
Yes, the new ones will slowly get old and develop rust and all that, but that will take many years and probably not be a problem until the brakes are next redone 50 years from now.
Old Apr 17, 2025 | 08:45 AM
  #84
As long as the width of the drum braking surface is the same you’re good to go. Adjust the shoes so they barely drag.
Old Apr 17, 2025 | 09:07 AM
  #85
72455's Avatar
1972 U code Supreme
Well, it's been an educational journey, but I think it's finally over. I just got back from a test drive and everything was good. She stops good and no vibration, and both drums barely reached 110 deg. I thank everyone for their advice and input.
Old Apr 17, 2025 | 09:58 AM
  #86
cjsdad's Avatar
Glad to hear it Dave! You're all set for some road-trippin this weekend!
Old Apr 17, 2025 | 01:03 PM
  #87
Good job, Dave.
Old Apr 17, 2025 | 01:54 PM
  #88
72455's Avatar
1972 U code Supreme
Good job, Dave.
Thanks Norm I'm glad it's done.
Old Apr 17, 2025 | 01:56 PM
  #89
72455's Avatar
1972 U code Supreme
Lol...the only road trippin I'll be doing is driving to work on Saturday
Old Apr 17, 2025 | 06:17 PM
  #90
72455's Avatar
1972 U code Supreme
Norm, just curious...do you have any how much heat is not dissipated with painted drums?
Old Apr 18, 2025 | 04:11 AM
  #91
jaunty75's Avatar
I'm sure all the heat is dissipated, it's just not dissipated as quickly. Although I personally wonder just how much a thin coat of paint would actually affect the rate of heat transfer through the drum.
If you do paint your drums, please take photos and show us! What color will you choose? Maybe each side could be a different color! How about taupe on one side and mauve on the other?
Old Apr 18, 2025 | 04:32 AM
  #92
Bfg's Avatar
Bfg
I would find something with a metal flake.
Old Apr 18, 2025 | 06:26 AM
  #93
Dave - Absolutely not. Sounds like a good research experiment you might pursue.
Old Apr 18, 2025 | 08:31 AM
  #94
OLDSter Ralph's Avatar
Poor dissipation of heat from a coat of paint is a crock of chit. People have been painting brake drums, califers and disc brake rotors for at least 50 years and no problems.
I would suggest VHT Hi Temp header paint. If you spray it on clean brake parts, it won't burn off. It comes in a variety of colors also.
Radiators in new cars were always painted semi gloss black. Someone on here claimed there was a special "radiator paint". I would think Oldsmobile engineers would have figured out a radiator would cool better without black paint. The factory didn't paint drums because they were hidden behind the fancy wheels.
Old Apr 18, 2025 | 09:27 AM
  #95
I painted my drums with VHT engine paint. They've held up nicely since 2009.
Brakes/Hydraulic Systems
53
Apr 13, 2025 07:25 PM
72455
Apr 25, 2024 02:29 PM
matchek
Apr 23, 2018 01:10 PM
cus
Oct 24, 2017 06:55 AM
My442
Nov 22, 2010 04:36 PM
