Spindles any good?
Old Dec 15, 2010 | 06:50 PM
oldzy's Avatar
Spindles any good?
I just had one turned on a lathe as it was chipped bad from a bad bearing a while back, but they are both about the same... when I put an smaller outer SET2 bearing on, hold it tight and try to move it back and forth to check for play... it moves ever so slightly on both of them. So it seems there is in fact a small gap in between the spindle itself and the bearing, as it is not a perfectly snug fit.
Should I just say screw it, give in, and get Chinese repros?
Old Dec 16, 2010 | 06:41 AM
507OLDS's Avatar
In my opinion,I think that's going to give you a vibration when you drive it because the inner sleeve is not snug with the spindle shaft.Yes,the bearing will spin,but it will also try to oscillate a very slight amount,which will cause a vibration.
Murco
Brakes/Hydraulic Systems
Mar 7, 2013 11:50 AM
rogiestone
Oct 18, 2011 06:11 PM
dhartley72
Mar 24, 2011 05:38 AM
oldzy
Suspension & Handling
Mar 10, 2010 06:34 AM
