Rear drums break locked up
I have a '62 Dynamic. I upgraded my front drums to disc brakes. I installed a master cylinder power booster and a proportioning valve. On my first ride out my rear wheels locked up. My car won't even move now. What could I do to fix this issue? Any advice would be appreciated.
What did you do to the rear brakes? New shoes, cylinders, hoses?
Dis you adjust your rear brakes according to specifications?
Did you adjust your brake pedal pushrod properly where it goes into the booster?
Yes, but did you leave the specified gap between the end of the rod and the bottom of the hole in the booster?
