Rear brake lines
Old Jan 17, 2013 | 04:06 PM
rmoths's Avatar
Rear brake lines
The brake line over the rearend going over to the drivers side has a crease in it. So I need to replace it. I see lines for sale "Made to fit". I never have luck with this, but maybe someone has ordered lines that do fit.
So where is the best place get brake lines that really fit nice.
Thanks Barb.
Old Jan 17, 2013 | 04:55 PM
Barb,
Try In Line Tube. I bought them for my 72 and am very happy with what' been installed so far. They use OEM parts as templates so the fit should be excellent. Your car is a 72 also so I would expect the fit to be excellent. see page 39 http://www.inlinetube.com/PDF%20cata...dsmobile03.pdf
Old Jan 17, 2013 | 05:01 PM
If you're replacing an original line into an original setup, the Inline Tube lines are nice.
Often, though, brake tubing and parts will have been changed over the years.
In that case, just buying a length of tubing with the appropriate nuts on the ends (about $4, if I recall), bending and cutting it to length, and re-flaring one end with a flaring tool (about $20, I think) will get the job done neatly and safely.
Old Jan 17, 2013 | 06:09 PM
Run to Rund's Avatar
You can usually buy a pre-made piece of brake line with nuts on it in a length close to what you want--try NAPA or CARQUEST.
Old Jan 17, 2013 | 10:19 PM
rmoths's Avatar
Ok! I know( Allen R) from alberta know what he's talking about.
So I will order from Inline tube for my brake lines.
Thanks Barb.
Old Jan 18, 2013 | 06:57 AM
Thanks Barb.
I got mine from Right Stuff and had no problems.
defiant1
Aug 22, 2015 08:49 PM
1k442
Dec 3, 2012 11:20 AM
65 starfire
Brakes/Hydraulic Systems
Feb 1, 2008 07:26 PM
54olds
Oct 31, 2007 07:24 PM
olds01
Aug 11, 2006 08:35 AM
