quick bearing/race question
Old Nov 11, 2012 | 11:17 PM
foo's Avatar
foo
I bought some new roters they have the races already in them, I also bought bearings that came with races.
My question is, would it be fine to keep the ones that are already installed in the roter or should I pop them out and use the ones that the bearings came with?
Old Nov 12, 2012 | 04:02 AM
I would always use the races that came with the bearings.
They should be matched.
Old Nov 12, 2012 | 05:59 AM
Run to Rund's Avatar
Bearings are made to the ten-thousands clearance and are very consistent. After they wear in, it is best to keep a race with its bearing. In this case with new stuff, it is fine to use the ones already in the hubs (assuming they are good quality parts).
Old Nov 12, 2012 | 06:22 AM
Eddie Hansen's Avatar
I would tend to agree with Eric on this one, only because you didn't say where the rotors were made , there could be a difference and to be safe I personally would use the races that came with the bearings as well , changing them is all of five minutes work . Just mho
Old Nov 12, 2012 | 06:28 AM
Rickman48's Avatar
Over the years, I've done them both ways, and never had a poblem either way,
Old Nov 12, 2012 | 06:33 AM
... Which is an assumption I was not brave enough to make .
Old Nov 12, 2012 | 06:41 AM
I'd rather be safe than sorry, I'd use the races that came with the new bearings. It only takes a few minutes to replace them.
scooter123
Jan 20, 2014 09:53 AM
nj_cutlass72
Mar 4, 2012 05:49 PM
Flye
Drivetrain/Differentials
Jul 30, 2009 10:24 AM
buddiiee
Jan 10, 2007 04:40 PM
coldfire
Jan 10, 2007 01:02 PM
