Proportioning valve question
Old Dec 17, 2013 | 09:45 PM
Fear Reborn's Avatar
I have all the parts needed to start the disk brake swap on a 70 chevelle ( yeah i know :\... its a 71/72 disk set up. the car is a manual drum car currently. i have the factory lines down to the prop valve. my question is will the lines that currently run to the metering block go right in to the prop valve? or will i need new lines to each caliper? thanks
Old Dec 18, 2013 | 02:36 PM
When you say "metering block", do you mean the drum brake distribution block? The lines will need to be rebent to fit, as the combo valve has the outlet ports to the front wheels at different angles than on the distribution block.
Old Dec 18, 2013 | 10:44 PM
yep thats the piece. so are the fittings the same also? all my original pieces are nice so trying not to replace unless i have too.
Old Dec 19, 2013 | 10:00 AM
The flare nuts for the front lines should be the same for drum and disk. If I remember correctly the rear port is a different size and will require an adapter fitting or replacement of the flare nut on the tube.
Old Dec 19, 2013 | 11:42 AM
thanks alot joe, exactly what i needed to know.
Old Feb 19, 2014 | 06:12 PM
rfmoody's Avatar
Adapter fitting
Joe, can you tell me where I can find an adapter fitting? I've looked everywhere I know and have had no luck. Thanks , Raymond
Old Feb 19, 2014 | 09:47 PM
Summit, NAPA, etc. Type "master cylinder adapter fitting" into Google and you'll get a long list.
oldspackrat
Oct 29, 2017 07:38 PM
Mike H.
Brakes/Hydraulic Systems
Mar 7, 2013 10:48 AM
Chumley
Mar 1, 2008 05:24 PM
Chumley
Feb 2, 2008 04:35 PM
W30post
Nov 25, 2007 10:18 AM
