power brake booster question
Old April 13th, 2009 | 12:32 PM
Vinny72olds's Avatar
Question power brake booster question
Hey fellow olds people,
I would like to know if there is a difference between power brake booster for disc and power brake booster for power drum or are they the same.
Old April 14th, 2009 | 07:44 AM
Bluevista's Avatar
Registered
In my '68 GTO the booster for front discs is larger in diameter than the drum.
I did a front disc conversion and used the drum booster with a disc MC for years with no problems.
I would assume it's the same with Olds, but we all know what assuming does.
Old April 14th, 2009 | 10:41 AM
delta88's Avatar
The booster itself should not matter. The proportioning valve is where a lot of the thinking is done in The brake system. Sometimes the master cylinder can change but usually for added capacity of fluid or different ratios of fluid.
Old April 16th, 2009 | 08:40 AM
Thanks for the help. Vinny
zodiacblueS
Brakes/Hydraulic Systems
44
October 12th, 2014 04:22 PM
Chumley
October 11th, 2010 09:25 AM
71supreme
April 7th, 2010 01:39 PM
iuhoops83
November 7th, 2008 03:04 PM
