power brake booster question
In my '68 GTO the booster for front discs is larger in diameter than the drum.
I did a front disc conversion and used the drum booster with a disc MC for years with no problems.
I would assume it's the same with Olds, but we all know what assuming does.
The booster itself should not matter. The proportioning valve is where a lot of the thinking is done in The brake system. Sometimes the master cylinder can change but usually for added capacity of fluid or different ratios of fluid.
zodiacblueS
Brakes/Hydraulic Systems
44
Oct 12, 2014 03:22 PM
