power booster
Old Jan 28, 2016 | 03:44 PM
willj's Avatar
power booster
hi , I checked all the auto parts company,s online ,they don,t list a booster for my 65 starfire , yet they list one for the 65 delta 88, I thought they where pretty much the same , can any body tell me why this match won,t work?thanks ,will.
Old Jan 28, 2016 | 05:37 PM
I'm gonna go out on a limb here and say the power brake booster for a '65 Delta 88 and a '65 Starfire would be identical. I can't think of a single reason why they wouldn't be.
Old Jan 28, 2016 | 11:21 PM
chequenman's Avatar
I don't see any reason why it doesn't fit. It probably doesn't list Starfire specifically
Old Jan 29, 2016 | 05:28 AM
lemoldsnut's Avatar
I've got a used one on a 65 Starfire parts car.
Larry
lemoldsnut@aol.com
Old Jan 29, 2016 | 06:27 AM
Oldsmaniac's Avatar
The boosters should be the same except if a manual trans booster is needed. They are smaller in size to clear clutch rod thru firewall if memory serves me.
Old Jan 29, 2016 | 06:45 AM
They are the same. Most on-line parts catalogs are riddled with errors and omissions. There are millions of parts and very little incentive to spend time fact-checking applications for obscure model variations on 50 year old cars. Your Starfire is a Dynamic 88 with different trim. All D88 suspension and brake parts are the same on a Starfire.
You think this is bad? Try ordering Oldsmobile motor mounts or water pumps...
Old Jan 29, 2016 | 06:50 AM
willj's Avatar
power booster
appreciate all the input, thanks ,will.
zodiacblueS
Brakes/Hydraulic Systems
44
Oct 12, 2014 03:22 PM
Chumley
Oct 11, 2010 08:25 AM
Vinny72olds
Apr 16, 2009 07:40 AM
iuhoops83
Nov 7, 2008 02:04 PM
