Need Lower Steering Column Bearing - Olds 98 1964
Old May 9, 2013 | 05:04 PM
fv64olds98's Avatar
Hello,
I was wondering if anyone has ever replace the lower bearing on the steering column on a olds 98 1964 with tilt steering
I am unable to find a replacement bearing. Does anyone know where I could buy such bearing?
Thanks for your help
Old May 9, 2013 | 05:24 PM
Octania's Avatar
I have a 64 Jetstar88 [big car] that might share that part.
I have had the non-tilt columns apart, easy. Replacing the lower bearing might be done w/o dismantling, did you ck the service manual procedure?
If you need the used part let me know.
Chris
517..449.Oh 432
Old May 9, 2013 | 08:05 PM
fv64olds98's Avatar
Hi Chris,
Thanks for the offering, the car is being painted and hope to have it back in a couple of weeks. I replaced the power steering gear thinking that could be the issue why the steering wheel was making noise when returning to the original position.
I know realize that the steering shaft is wobbling in the lower part of the steering column and rubbing against the inside of the column.
I have the manual from oldsmobile and there is a bearing that goes there, but I am 100% sure mine is either gone or completely destroyed
62 Olds
Mar 24, 2015 06:51 PM
john116
Feb 8, 2014 12:13 PM
RandyS
Aug 26, 2012 12:58 PM
67442nut
Dec 26, 2010 11:07 PM
7244too
Nov 6, 2008 09:27 AM
