Master Cylinder Hose Question
I have recently purchased an 1946 Olds 98 Custom Cruiser. She has been customized with a lot of upgrades, but she is an uncompleted basket case.
She has been upgraded to 4 wheel vented discs with a dual master cylinder located under the drivers seat. The check valve barb on the MC accepts an 3/8" hose. Can I use an 3/8 rubber fuel line to run the approximate 4 feet to my connection on the intake manifold or do I need something more substantial?
There are no "hoses" on the master cylinder. I ASSUME you are talking about the rubber vacuum hose that supplies vacuum to the brake power booster. If so, then fuel hose is the correct material to use.
Thank you for your help.
Del70
October 14th, 2010 04:55 PM
