Master Cylinder Hose Question
I have recently purchased an 1946 Olds 98 Custom Cruiser. She has been customized with a lot of upgrades, but she is an uncompleted basket case.
She has been upgraded to 4 wheel vented discs with a dual master cylinder located under the drivers seat. The check valve barb on the MC accepts an 3/8" hose. Can I use an 3/8 rubber fuel line to run the approximate 4 feet to my connection on the intake manifold or do I need something more substantial?
There are no "hoses" on the master cylinder. I ASSUME you are talking about the rubber vacuum hose that supplies vacuum to the brake power booster. If so, then fuel hose is the correct material to use.
. This is my first vintage car with the luxury of power brakes. I'm used to 80 year old drum brakes.Thank you for your help.
