Looking for an MC Rebuild kit 1 inch bore.
I am looking for a master cylinder rebuild kit for a 71 CS with Power Drum Brakes (no disk).
The manual indicates that I have a delco morane MC with a 1 inch bore.
The MC on my car is factory original.
Most of the stores / web that sell replacement kits do not post the bore size.
A friend of mine doing the rebuild just bought a kit and got the 1- 1/8 bore, which we found out later is only for the cars with Front disk/Rear drum.
Suggestions welcome.
Thanks Retro,
I did find the #MK497 on the Raybestos web site, but could not find the bore size on the specification. Interesting the Rock Auto has the bore size clearly listed.
Thanks.
Thanks.
Need Secondary Piston
I bought a Master Cylinder rebuild kit from Rock auto with a 1” bore for my 71 CS power drum setup.
The kit had springs, gaskets and one Primary piston.
The kit does not include a Secondary piston.
My existing Secondary piston (aluminum) is all pitted. See attached pictures.
The question is, where do I get a Secondary piston with a 1” bore for my 71 CS?
Rock Auto does not carry them.
Below is a picture of my Secondary Piston. Notice the pitting.
![](/forums/attachments/brakes-hydraulic-systems/84332d1391130774-looking-mc-rebuild-kit-1-inch-bore-dsc08862.jpg)
rebuilt unit
orially has rebuilt units you can use the rebuilt unit are if u want to keep your original unit u can maybe swap the parts from the meman. unit to your original unit. these units are cheap like 20.00 to 30.00 a peace. just an idea I thought of running by u hope this helps
thanks ray
thanks ray
I did end up buying a full MC and then removed the parts and put them in my original MC.
The new parts were identical.
Now I just need to paint and install and see whathappens.
Moral of the story, If you want to rebuild your old MC, just by a new one and swap the parts.
dz442
September 6th, 2019 03:55 PM
1971viking
Brakes/Hydraulic Systems
December 18th, 2012 05:22 AM
Eddie Hansen
Drivetrain/Differentials
March 31st, 2010 09:54 AM
