Largest size rotors with stock 15 rallys
Old Aug 17, 2024 | 07:50 PM
JAXX455's Avatar
What’s the largest size rotors I can put on my 72 Cutlass with stock 15 rallys? I came across some 14 inch rotors disc brakes. Will they fit?
Old Aug 17, 2024 | 08:09 PM
I just snapped this picture of a 15” SSIII wheel.
Old Aug 17, 2024 | 08:17 PM
... so, no.
Old Aug 17, 2024 | 08:19 PM
Loaded68W34's Avatar
No, 14" rotors will not fit inside a 15" wheel (unless you do not plan to use calipers). Here are my 14" rotors on the front of my vista cruiser. With an 18" wheel there is only a little over 1/8" between the caliper and the wheel. When I had the tires balanced, the shop used 2 layers of stick-on wheel weights in a couple spots. After a revolution, those areas were down to 1 layer of weights. You might get away with a 12" rotor, but in most cases even they require at least a 16" wheel.
Old Aug 17, 2024 | 08:27 PM
JAXX455's Avatar
... so, no.
Damn, guess not😂
Old Aug 17, 2024 | 08:31 PM
JAXX455's Avatar
Damn that’s a tight fit! But you’re tellin me there’s a chance if I put my 18s on huh? I have the same wheels. Boss 338. But I like riden my rallys too.
Old Aug 18, 2024 | 05:45 AM
First of all, clearance depends on BOTH the rotor diameter AND the caliper configuration. Wilwood has templates of their calipers that can be used to check clearance.
Second, the factory 15x7 SuperStock ("Rally" is a Chevy wheel) uses the same center stamping as does the 14" SuperStock wheel. That means that 15" versions use a special rim that has a greater amount of "drop" in the center to mate up with that center stamping. The result is that the Olds SuperStock wheels DO NOT clear the same calipers as will other 15" wheels. Diameter isn't the only thing that matters. I would expect that the factory 15x7 SuperStock wheels won't clear anything larger than the OEM 10.75" rotors and D52 calipers.
Old Aug 18, 2024 | 11:52 AM
Fonz's Avatar
wasn't aware that 1970-72 cutlass ever came with stock 15" Olds rally wheels ! I've a bunch of the 14 x 7s
Old Aug 18, 2024 | 11:55 AM
They didn't. Other than the 69 H/O, 1973 was the first time 15x7 SuperStock II or III wheels were available.
Old Aug 26, 2025 | 08:45 PM
hystat's Avatar
On my 73 cutlass supreme,
Wilwood D52 calipers wouldn't even clear my 15" SSII's. I have the powerstop rotors
I'd have to modify the caliper or use a wheel spacer
Old Aug 27, 2025 | 08:02 AM
VC455's Avatar
Barely Registered
That was my experience as well.
Old Aug 27, 2025 | 07:00 PM
Let's all keep in mind that the SS II/III wheels use the same center disc for both 14" and 15" versions. The 15" wheels have a special hoop that has a dropped center section to match the ID of the 14" hoop. The result is even less caliper clearance than for a normal 15" steel wheel.
Old Aug 28, 2025 | 12:13 PM
Here's an illustration of why SS II/III wheels do not provide the same clearance for disc brakes that other 15" wheels provide. The use of the same center as on the 14" wheels results in less room for the calipers.
Zabbs22
May 24, 2023 06:57 PM
71OldsCut
Brakes/Hydraulic Systems
Oct 8, 2020 05:02 AM
boc23
Apr 15, 2020 09:43 PM
Tiger69
Wheels and Tires
Jan 19, 2018 05:33 PM
1968Cutlassfallbrook
Wheels and Tires
May 22, 2011 09:26 AM
