how to clear brake codes (94 ciera)
Old Oct 16, 2007 | 10:12 PM
fisherman1962's Avatar
Hello everyone, I have A 94 ciera with abs, I put in new rear brakes, then bled them. Upon completion, I started the car and both, the "abs" and "brake" lights are on. Do I just disconnect the battery, or is this a special procedure to clear the codes. Thanks in advance.
Old Oct 17, 2007 | 04:53 AM
Oldsguy's Avatar
Past Administrator
What does the owner manual say about that, anything? Sometimes disconnecting power to the computer will at least re-set the computer to a nuetral mode until it can gather sensor readings and compile a new data base, that might help. But it might not.
Old Oct 17, 2007 | 05:30 AM
I doubt disconnecting the battery will clear your codes since your car is a 94 Cutlass (this means it is probably OBD 2 with a Keep Alive Memory). You need to go to the auto parts store and have them read your codes. Then depending on what codes are in your ECM you can have them cleared.
Old Oct 17, 2007 | 02:32 PM
thanks for your help, I will try disconnecting the battery first, if it doesnt work i"l take it to an auto parts store, thanks again.
Old Oct 17, 2007 | 05:04 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
It usually hAS something to do with the brake pedal. Damn... I forget.
Something like hold it for 15 seconds and then pump it a certain number of times or something like that.
Sorry.
Del70
Sep 30, 2014 07:21 PM
virtualwsp
Brakes/Hydraulic Systems
Jun 13, 2012 02:00 PM
ztim
Jul 11, 2007 04:18 PM
Want-A-Vert
Feb 3, 2007 11:23 AM
HWYSTR455
Aug 30, 2006 04:40 AM
