Help Picking a good front disc brake kit.
Old Sep 10, 2012 | 09:05 PM
Z-Fitch's Avatar
hey guys I need you help picking a good disc brake kit that's not going to have my wife going nuts.I have a $600 price limit..I have a 1969 cutlass S and I found a kit on ebay but wanted to know if someone has used it or know about this kit good or bad. Also open to hear about others disc brake kits that I should look into. If someone has a diagram of my car that would be great to have or even know a link please let me know.
Thanks guys
http://www.ebay.com/itm/Gm-Power-A-F...ht_2374wt_1196
Old Sep 11, 2012 | 04:40 PM
Porter858's Avatar
The cheapest decent disc conversion I’ve seen is different kits from The Right Stuff Detailing. I haven’t personally used one of their kits yet, but I plan on giving their 4 wheel disc kit a shot in the near future.
Check around of the forums about this brand. The little research I’ve done on it, it seems like most guys are more than happy with these kits for daily driver cars just looking for a disc upgrade, and not overly concerned with being totally factory correct. Non-race stuff in other words.
This kit here is hard to beat pricewise since it’s so complete. $505.75 including a new master and booster. They also have all different levels of kits if you’re really trying to keep on a tight budget.
http://www.summitracing.com/parts/RSD-AFXDC01C/
* Front rotors
* Bearings
* Grease seals
* Spindle gaskets
* Dust caps
* Castle nuts
* Washers
* Cotter pins
* Caliper brackets
* New front calipers
* Organic pads
* Flex hoses
* Flex hose clips
* Banjo bolts
* Steering arm bolts
* Master cylinder
* Combination valve
* Valve bracket
* Valve hardware
* Brake switch pigtail
* Pedal rod extensions
* Vacuum hose
* Power brake booster
* Power brake booster brackets
Last edited by Porter858; Sep 11, 2012 at 04:44 PM. Reason: I just noticed this "could" be the same brand of parts you're already looking at on Ebay, only they are the drilled ones.
Old Sep 11, 2012 | 04:46 PM
Eddie Hansen's Avatar
What porter said I used the 4 wheel disc set up from them they are at www.getdiscbrakes.com they were extremely helpful and their service was second to none, look at my thread in major builds and you can see the kit , I went a little overboard with powder coating calipers stainless lines 9 inch delco booster to give me some room with the 455 valve covers , I also upgraded to stainless steel hoses. It was a straight forward and easy kit to install just my humble opinion haven't driven the car yet but I can not say enough about there service etc they went way above and beyond
Old Sep 12, 2012 | 05:00 AM
Z-Fitch's Avatar
Thanks guys I will be looking into this and will get back to let you know what happens.
Mocephus
Oct 1, 2021 09:45 AM
Bglad
Brakes/Hydraulic Systems
Apr 19, 2015 11:25 AM
cutlassjoe
Mar 20, 2015 10:14 PM
yeahbuddy
Feb 12, 2014 07:14 PM
Charles Welty
Dec 3, 2010 07:44 AM
