Help naming part and parking brake ratcheting issue
Old November 2nd, 2018, 04:27 PM
Joe Ralph
72442455's Avatar
72442455 is offline
Old November 2nd, 2018, 04:30 PM
Joe Ralph
72442455's Avatar
What’s the name of that flying saucer looking spring backing plate that goes on the upper pin in drum brakes? (72 cutlass convertible) and anyone know where I can get a replacement? (Lost one &#128553 -on a separate note - my parking brake doesn’t ratchet - if I step on it it will stop the brakes but it won’t click to hold them - any ideas? Thanks in advande gang! - Joe R.
72442455 is offline
Old November 2nd, 2018, 04:36 PM
Joe Ralph
72442455's Avatar
CSM simply calls it a “guide”
72442455 is offline
Old November 3rd, 2018, 03:45 PM
Which it is - it guides the upper end of the shoes back into position against that pin when you release the brakes.
On the parking brake, are you saying that the parking brake pedal doesn't stay in the depressed position? If so, either the release handle is stuck in the pulled out position or the pawl that ratchets against the pedal arm is stuck (check for rust on the pivot pin) or the spring on that pawl is broken.
joe_padavano is offline
Old November 3rd, 2018, 04:50 PM
Joe Ralph
72442455's Avatar
thanks as always Joe - guide plate on order - as for the parking brake - that is correct - I will check out the release handle, pivot pin, and the spring on the pawl and let you know what I find. Thanks again - Joe R.
72442455 is offline
Old November 3rd, 2018, 04:52 PM
2blu442's Avatar
These guides are a common part and I would think available at your local parts supplier. Did you find one yet?
John
2blu442 is online now
Old November 4th, 2018, 02:40 AM
Joe Ralph
72442455's Avatar
John
nobody has it - not napa - not advanced auto parts - not o’rileys - not aci auto parts warehouse - tried a local speed shop and nope - tried a brake and muffler business nope - had it been any single other piece ... no problem / it would be part of a kit - but not this
72442455 is offline
Old November 4th, 2018, 02:42 AM
Joe Ralph
72442455's Avatar
I’ve got one on order - used a washer as a place holder in the meantime
72442455 is offline
Old November 4th, 2018, 05:28 AM
They are not a normal wear item, thus there is no reason for a store to have one in stock.
Old April 9th, 2019, 01:18 AM
Joe Ralph
72442455's Avatar
Well the weather has gotten nicer and back to work on the Olds - the parking brake cable Adjusted nicely - car keeps on surprising me how good of shape it is in with little rust - the issue with parking brakes is the ratcheting foot pedal - if I kick the release handle and twist the whole assemble left or right I can kinda get it to hold but the slightest bump will release it - is this something that I can clean up and make work nicely or should I just replace it?
72442455 is offline
kbdecatur
Brakes/Hydraulic Systems
April 9th, 2019 06:16 PM
Dylan Conaway
January 14th, 2017 12:41 PM
Redog
April 17th, 2015 01:17 AM
Kilmster
August 6th, 2014 05:41 PM
Quick Reply: Help naming part and parking brake ratcheting issue
