Brake noise
Brake noise
72 cutlass disc brakes when I release the brake pedal I hear a loud clunk on the drivers side. Also when I ride over speed breakers I hear the same noise. Has anyone ever had this happen?
I recommend you have it checked out soon. Could be something mundane like sway bar linkage, or could be something safety related like missing or broken brake hardware. I've even had control arm shims fall out,, resulting in a hard pop when going from reverse to forward. The brakes put stress on everything since these are a direct link between your car and ground. Consequently, it is difficult to diagnose without putting it up on stands, removing wheels and giving things a close look.
It could be many things as everyone said, but you'll have to do more than just listen to it to find out. Raise it up carefully and look for things like worn out bushings or ball joints.
One way to locate loose steering components is to have someone move the steering wheel back and forth while you look at the front end parts. Slack in tie rod ends, idler arm, etc will be visible.
X2 on having an assistant turn steering wheel slowly in each direction. Any worn tie rods, idler arm and/or center link joints will be quickly obvious. However, i’ve never had worn linkage manifest itself in a clunk or thud. Rather a shudder or wandering at speed. Ball joints require different but similar inspection methods. Some have inspection gauges on the lower’s grease zerk area. But, normally you just jack up under the lower control arm to remove car weight (and spring load) from ball joints. You can temporarily reinstall the wheel to use as leverage. Grip the wheel at 12 & 6, rock, and watch the joints for relative movement. Again, easier to do with a helper.
Brake noise
Well It was the upper control arm bushings. One of them was completely shot. It had no rubber in it..Well it’s all fixed now and I’m going to the alignment shop ASAP. Thanks again..
Glad to hear you figured it out😀. Did you have to remove the control arm to replace the bushing?
Dylan Conaway
Brakes/Hydraulic Systems
January 14th, 2017 12:41 PM
wheels442
Suspension & Handling
February 1st, 2015 11:04 AM
delta_88_germany
November 2nd, 2013 05:06 AM
DANGER21310
July 18th, 2013 04:50 PM
