front housing seal
Old May 30, 2014 | 08:53 AM
Macadoo's Avatar
front housing seal
I'm bleeding my new MC right now but I was wondering if I should lube the front housing seal on the booster (power cylinder) before bolting up the MC. The CSM doesn't mention it but I thought I would ask.
Old May 30, 2014 | 09:01 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Not necessary. Make sure that boot is soft and not torn. Replace it if needed. Clean the boot and MC mating surfaces and bolt er up.
Old May 30, 2014 | 09:08 AM
Macadoo's Avatar
Awesome. Thanks Doc. Boot looks to be in excellent shape. Soft, no tears, not warped.
Old May 30, 2014 | 09:19 AM
Macadoo's Avatar
This bench bleeding takes a while, huh? Been at it for 25-ish minutes and still tiny bubbles.
Old May 30, 2014 | 09:40 AM
boese1978's Avatar
Sometimes air will be drawn in around the cheap plastic fittings they give you to attach to the MC.
Old May 30, 2014 | 10:16 AM
Macadoo's Avatar
Nah, I finally got it. But only after dumping the fluid out and cleaning out the paint flecks three times. Why do they paint the inside orifices?
smcurro
Mar 16, 2018 08:37 PM
dynamic88
Aug 30, 2007 11:43 AM
kcompton
Nov 16, 2006 04:42 AM
Wes
Aug 21, 2006 01:26 PM
Sixoh
Aug 8, 2006 05:11 AM
