Front drum with bolt at top - seeking diagram or pics
Old Apr 7, 2021 | 03:33 PM
seanm12's Avatar
I have a 67 Cutlass and the front drums have a bolt at the top instead of a pivot pin. I have gone through a few posts but most pics don't show this design. I want to replace the springs and follow a picture. The service manual has pictures of the other design. Thanks for any help and tips.
Old Apr 7, 2021 | 03:40 PM
Those springs look fine to use over, I hardly ever change springs if they are clean and serviceable. You can take a picture of your brake assy before you start and/or do one side at a time so you can use the other side as reference.
Old Apr 7, 2021 | 03:59 PM
seanm12's Avatar
Well, this is my work that I did a few years ago. I have looked over more pics and for the springs in the middle . I did just figure out between yellow and green one is longer, so that needs a correction. Besides that I am not sure if the top springs are correct, so getting another pic or diagram where both top springs are the same would be good to compare.
Old Apr 7, 2021 | 06:11 PM
Here is a link to another thread with bolt instead of pivot pin & a lively conversation which you may have already reviewed. I can't speak for either what is or is not correct - this is a disclaimer. I'm merely a messenger.
1967 cutlass front drum brake springs
Old Apr 9, 2021 | 05:16 AM
sysmg's Avatar
I have also seen it both ways. Been working on these since 1970.
Old Apr 10, 2021 | 05:50 AM
seanm12's Avatar
Vintage Chief, that link is helpful. Thank you!
Tjohn8573
Sep 13, 2019 02:31 PM
71OldscutlassS
Suspension & Handling
Jul 27, 2019 08:44 AM
tonyhuntsberger
Non-Olds Engines
Jul 8, 2018 01:38 PM
442oldz71
Apr 28, 2018 10:35 AM
72Cutlass
Apr 12, 2008 07:54 PM
