emergency brakes
Old May 1, 2008 | 07:55 PM
70redvert's Avatar
emergency brakes
'70 Cutlass,
I can not depress my emergency brake pedal at all. Where would I begin to look to see whats locked up. Drum brakes on the rear.
Old May 2, 2008 | 12:02 AM
daverbmxer's Avatar
It's likely that the cable has seized in the housing. If it does indeed look old replace it.
Old May 2, 2008 | 02:26 AM
Jim's rare 80's Avatar
Jim's rare 80
Probably the front cable that goes through the firewall. Try pulling on the cable from underneath, and see if you have any movement from the rear cables. It is probably the front. If it was the rear, you would have some movement at the pedal.
Let us know.
Old May 2, 2008 | 04:44 AM
Oldsguy's Avatar
Past Administrator
I agree with Jim, cable. You may be able to free it up if you can see and access where the cable passes through the firewall and be able to insert the nozzle of something like PB Blaster and "douche" the cable well with that, allowing the penetrant to fully saturate the cable. It should, over time penetrate enough to run all the way down, inside the housing of the cable and drip out where the housing terminates maybe under the floor pan someplace.
Old May 2, 2008 | 05:31 AM
70redvert's Avatar
Thanks, I'll pull it out this weekend and will see what happens.
Old May 2, 2008 | 04:37 PM
Dapapadon's Avatar
If the bottom of the windshield was leaking from rust it may be the pedal assembly. I had to replace the one on my 67' Cutlass. The cable was fine.
Don
Old May 9, 2008 | 09:38 AM
ztim's Avatar
I had the same problem with my '84 88 and had to replace the cable. That was so much easier and now I have no worries parking on the boat ramp while putting the boat in the water.
1973olds98
Brakes/Hydraulic Systems
Aug 15, 2010 06:18 PM
croozer
Jul 14, 2010 02:36 AM
ztim
Feb 26, 2007 04:35 AM
mitsudave
Jan 19, 2007 06:56 PM
dynamic88
Oct 18, 2006 06:17 AM
