Dual master cyl
Old Apr 19, 2011 | 04:47 PM
jag1886's Avatar
Dual master cyl
I have not seen this anywhere. How can you convert a single cylinder 65 Cutlass with power brakes to a dual cylinder with proportioning valve. I don't want disc brakes the drums work fine. I would just feel safer when I'm in the mountains that if something popped I wouldn't loose everything.
Old Apr 19, 2011 | 07:33 PM
TripDeuces's Avatar
Many places sell that set up. SSBC, Right Stuff, CPP, etc, etc.
Old Apr 19, 2011 | 07:56 PM
There is no proportioning valve in a drum/drum system, just a distribution block with the differential pressure switch that lights the BRAKE lamp on the dash if you lose pressure in one side. The dual circuit M/C requires a different booster, or at least a shorter pushrod between the M/C and booster.
Old Apr 19, 2011 | 11:49 PM
Dapapadon's Avatar
The thread below explains it a little more. The easiest way is to use a 67 booster & master cylinder.
https://classicoldsmobile.com/forums...ngle-dual.html
Hope this helps.
Don
Delmont 88 PA
Apr 26, 2015 05:28 PM
NDERISE
Feb 1, 2014 10:25 AM
hurstman1972
Brakes/Hydraulic Systems
Oct 5, 2012 11:47 AM
68conv455
Jan 12, 2010 03:39 AM
aastm15
Jul 11, 2008 06:09 AM
